SP6 template from Grandstreamexecutive
Discussion in '3CX Phone System - General' started by millsey, Feb 18, 2012.
  1. millsey
    millsey New Member
    Dec 21, 2011
    190
    We have our own template for Grandstream GXP2100 and after upgrading to SP6 I replaced the new SP6 provided template with our own. The updated blog post now says that:
    Fixed: Grandstream crash related to BLF Keys caused by a firmware update (Re-provision required)
    I guess there is something different in the new template which I need to identify - our own template may have an error in it from the original taken from SP5. So could some kind soul please post the content of the 3CX grandstreamexecutive template.
    We need to use our own because of things like handset volume which is not configurable without editing the template.
    Thanks!
    Millsey
  2. RLester
    Feb 16, 2012
    44
    ONLY THING I HAVE CHANGED IS DTMF, I USE SIP INFO
    THE ORG FILE WAS SET TO P2301=1 AND P2303=0
    # Send DTMF. 0 - no, 1 - yes
    # in-audio
    P2301 = 0
    # Via RTP (RFC2833)
    P2302 = 0
    # Via SIP INFO
    P2303 = 1
    END OF MY EDITS
    3CX FILE START BELOW HERE
    !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!HAD TO SPLIT FILE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    [Use "code" to post content of the log and files]
  3. RLester
    Feb 16, 2012
    44
  4. RLester
    Feb 16, 2012
    44
    You wouldn't hapen to use a PSTN Gateway do you and if so would it happen to be a GXW41XX? I am haveing trouble with VoIP to PSTN dialing.
  5. millsey
    millsey New Member
    Dec 21, 2011
    190
    Thanks for posting. We are SIP only except for a Patton 4xxx box as an FXS for some legacy conf phones.
  6. RLester
    Feb 16, 2012
    44
    Who is you SIP or VoIP provider and I would guess you’re happy with the service?
  7. millsey
    millsey New Member
    Dec 21, 2011
    190
    We are using NODE4 for our SIP trunk, they are very good value but we have had a few issues. They don't support the VIA header as per the RFC specification but that can be got around by a firewall doing packet inspection. We haev a Cisco ASA5505 which is not expensive and does this inspection well (change teh VIA header tot eh external IP address of hte switch instead of it being the internal IP addres)
