SPA 303 not provisioning
Discussion in '3CX Phone System - General' started by PatrickTodd, Feb 12, 2016.
  1. PatrickTodd
    Jan 12, 2016
    40
    6
    So I followed the http://www.3cx.com/sip-phones/cisco-spa/ how-to and also updated the SPA to the latest firmware (7.6.1)
    I entered the provisioning link but the phone does not seem to want to provision. Is the SPA 303 still supported or are the instructions different?
    I also have option 66 setup which works for the fanvil and yealink phones I have.
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,367
    83
    They are still in the list of supported devices: http://www.3cx.com/support/
    I just pulled one out to test it and it was on v7.5.5 at the time. From that time a tried:
    - Provisioning it from a Factory Reset it state on v7.5.5.
    - Upgrading the Firmware from the Management Console to v7.6.1.
    - Provisioning it from a Factory Reset it state on v7.6.1.
    All of the above worked fine, except for the last one in which case I had to reboot it through the phones menu, but I probably did something else wrong.
    Also it is worth noting that I had the latest V14 Cisco template when I tried the above.
    One common mistake I have seen though generally is, remember not to use the https provisioning link, cisco phones only support http prov links so adjust the port also accordingly.
