SPA-3102 and 3cx : Can't see Caller-ID
Discussion in '3CX Phone System - General' started by stamos, Jul 24, 2007.
  1. stamos
    Jul 24, 2007
    5
    I can't see the Caller-ID on the logs of 3cx and also on the phone screens.
    I am using Linksys SPA-3102 for attaching the PSTN Line.I can see the caller-id on the Linksys-SPA-3102 .
    Does anybody had the same problem with me and solved it ?
    Thank you
    Stamos
  2. jits04
    May 2, 2007
    76
    set PSTN Answer Delay to: 3 (or 4)
    Bye
    William
  3. Anonymous
    Anonymous Guest
    William, that is just slack LOL.
    It is a bit more involved than that.
    In 3CX you have to configure:
    Edit VoIP Gateway
    Gateway capabilities: Supports re-Invite tick this
    Location of destination number:
  4. stamos
    Jul 24, 2007
    5
    Thank you ,
    I have done all these , but I had also to do the following on the Sipura-3102:
    PSTN Line
    PSTN CID For VoIP CID:Yes
    Now it works.
    Thank you
  5. Fallout
    Oct 10, 2006
    12
    Everyone misses this...It is the most important part....
  6. Anonymous
    Anonymous Guest
    I guess it is so obvious that it is not mentioned.
    But good point, Ill make sure i add it to the doco.
  7. onekit
    Aug 3, 2007
    27
    With such setting my phone (which connected to SPA port "Phone") ring for this time and then redirect to 3CX.
    It seems like I hear the ring on the phone which I don't want ring.
    My 3cx phone system redirect calls to another sip phone, not connected to SPA.
    I know this issue is not associated with 3cx, it's trouble of SPA-3102, but may be you know solution how to keep phone in silence.
    Added:
    If I set PSTN Answer Delay: 1.5 - then connected phone silent.
    And one question: May be I need additional phone with ability Caller ID detection? Or my SPA-3102 must detect caller ID self?
  8. onekit
    Aug 3, 2007
    27
    What about settings in "Voice -> Regional" tab?
    Exactly fields "Caller ID Method" and "Caller ID FSK Standard". Is it important? I think it so.
  9. Cjay
    Cjay New Member
    Feb 24, 2007
    203
    5
    This depends on your caller ID system. For example in the UK the CID data is sent as FSK before the first ring, so you can set the answer delay to 0. This makes my VoIP phones ring at almost the same time as the conventional analogue phones. Other CID standards send the CID data burst between the first & second ring - in which case you do need the answer delay.
    You must set your Caller ID method to the correct standard, so the regional setting is important!
    Cjay
  10. Anonymous
    Anonymous Guest
    Correct Cjay,
    appart from that it only works with the BellCore standard (again one of those undocumented gotchas).
  11. onekit
    Aug 3, 2007
    27
    My problem was in PBX.
    And works good with such settings:
    PSTN Answer Delay: 2
    PSTN Ring Thru Delay: 1
    But now I need to convert caller id number to international format. ;) But it's offtopic already.
