SPA 3102 Continuous Registration
Discussion in '3CX Phone System - General' started by comresource, Jul 30, 2009.
  1. comresource
    comresource Member
    May 22, 2009
    303
    We received a 3102 a couple of days ago for demo/testing and I decided to unbox and bring it home. I hooked an analog phone to it and it is registered to 3CX back at the office as an extension. Voice works fine but my question is that the 3CX logs are showing it re-registering every 1-2 seconds. I have tried to tweak the settings that are registration related but to no avail. Is this a common happening with this device or do I have someting misconfigured?
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    I have never had a linksys SPA-3102 do that before except in one instance where UPNP on a router was borking the connection, Have you tried to reset to factory defaults?
  3. comresource
    comresource Member
    May 22, 2009
    303
    Yes, I had just factory reset it before I configured it. My home router is 'currently' a Cisco UC520 that I have been playing with so it may be doing something funky with the connection. When I get a chance I will try it with with something else.
  4. leejor
    10,586
    252
    The router shouldn't affect the registration time. Is it set for approx 3600 (seconds)? The provider (the 3CX in this case) can override your settings for registration but it shouldn't be doing it that often. Do you have any other devices registering with 3CX, if so,what are their intervals?
  5. comresource
    comresource Member
    May 22, 2009
    303
    I brought it into the office this morning and registered it as both an ATA and a PSTN gateway and it is working fine with normal registration intervals now.
  6. leejor
    10,586
    252
    Was it both the FXO and FXS ports that were registering every 2 or 3 seconds.
  7. comresource
    comresource Member
    May 22, 2009
    303
    At home was only using Line1 and not the PSTN line.
  8. leejor
    10,586
    252
    You could try using the syslog feature on the 3102 to analyse why it is registering that often. Perhaps it isn't happy with the response or getting no response from the 3CX.
  9. comresource
    comresource Member
    May 22, 2009
    303
    Actually I did just that. I was running syslog on my laptop but I received very little information. I will take it home again tonight and see if it does the same thing. If I see the same thing I will grab a sniffer trace and post it.
  10. comresource
    comresource Member
    May 22, 2009
    303
    Ok, back home and seeing the same thing. Here is what syslog is showing...
    Code:
    07-30-2009	19:01:19	Local2.Debug	192.168.20.13	[5060]STUN trying 0
    07-30-2009	19:01:19	Local2.Debug	192.168.20.13	[5060]STUN trying 1
    07-30-2009	19:01:19	Local2.Debug	192.168.20.13	[0]REG: STUN c0a8140d->41ba5abb, 5060->1266
    07-30-2009	19:01:19	Local2.Debug	192.168.20.13	[0]ExtSipPortChanged:0
    07-30-2009	19:01:20	Local2.Debug	192.168.20.13	[0]ExtSipPortChanged:0
    07-30-2009	19:01:20	Local3.Debug	192.168.20.13	[0]RegOK. NextReg in 1 (1)
    07-30-2009	19:01:21	Local2.Debug	192.168.20.13	[5060]STUN trying 0
    07-30-2009	19:01:21	Local2.Debug	192.168.20.13	[5060]STUN trying 1
    07-30-2009	19:01:21	Local2.Debug	192.168.20.13	[0]REG: STUN c0a8140d->41ba5abb, 5060->1266
    07-30-2009	19:01:21	Local2.Debug	192.168.20.13	[0]ExtSipPortChanged:0
    07-30-2009	19:01:21	Local3.Debug	192.168.20.13	[0]RegOK. NextReg in 1 (1)
    07-30-2009	19:01:22	Local2.Debug	192.168.20.13	[5060]STUN trying 0
    07-30-2009	19:01:22	Local2.Debug	192.168.20.13	[5060]STUN trying 1
    07-30-2009	19:01:23	Local2.Debug	192.168.20.13	[0]REG: STUN c0a8140d->41ba5abb, 5060->1266
  11. tpinnovations
    Jul 30, 2009
    296
    If its working fine on the LAN, But not on the WAN that leads me to believe the issue resides within the router or the config on the 3102.
    Have you tried;
    fixup protocol sip 5060
    fixup protocol stun 3478
  12. comresource
    comresource Member
    May 22, 2009
    303
    Unfortunately I am not using a PIX at home just IOS Firewall on the UC520. But I am sure your right about it being a NAT issue with my router. I will dig a bit more into this this weekend. I do have a old spare PIX 501 sitting here on my desk. I may take it home with me tonight and see if it helps out.
    Thanks.
  13. leejor
    10,586
    252
    Correct me if I'm wrong but he logs look like the "registration" with the STUN server not the 3CX. That would be a different group of settings in the 3102 where you can specify how often it will go out to the STUN server. The 3102 might be having STUN problems behind your home router.
