SPA-3102 Fix
sigma1
Not too long ago I was browsing for a solution to why the 3102 doesn't pass the caller ID. I saw everything from increasing this time to the other thing.
Here's the solution (replace template)
  • 3102.txt
In North America this value really needs to be a "3" or above to collect the CID info. Otherwise the 3102 doesn't wait long enough before sending the call info on to 3CX.
I'm assuming that this provisions the 3102 with a "0"
<PSTN_Answer_Delay_2_ ua="na">0</PSTN_Answer_Delay_2_>
And this (yes) sends incoming PSTN calls through to the FXS jack, which is fine if you don't want to use the 3102 as a 3CX trunk.
<PSTN_Ring_Thru_Line_1_2_ ua="na">Yes</PSTN_Ring_Thru_Line_1_2_>
Getting Started - Admin
damiano giannini
Get 3CX - Absolutely Free!
3CX
