SPA 3102 good solution for 3CX with standard (PSTN) line?
Discussion in '3CX Phone System - General' started by mutti_wilson, Jun 20, 2008.
  1. mutti_wilson
    May 2, 2008
    53
    I have been using a VOIP provider and the delay and quality just isn't there, so we are going to go back to the standard line we have been using as a backup. I am looking at the SPA3102 to connect the standard line to the 3CX and use the IP phones as our extensions. Is this a good way to go or is there a better adapter? I will not be using any VOIP, just a standard line so what is the easiest way to set it up? Thanks.
  2. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hi
    we are using this adapter for more than a year working fine, may i suggest to get another Voip line and test it, depending on your location you can get it free
    regards
  3. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello
    I'm new in voip
    but i noticed that the calls voip to voip ith very clear but voip to bstn using spa3102 is not clear like voip to voip
  4. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    I have used the Patton 4112 and 4114 gateways with great sucess. They are more expensive than some but give excellent quality and no problems so far.
  5. ess
    ess New Member
    Jun 8, 2007
    133
    I use two of these adapters in a small business, and I have no real issues since they have been setup. Setting them up took a little work, but now there are plenty of guides and help on the forums for a painless install with 3cx.
  6. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    Sorry, was not intending to infer anything negative about the SPA 3102, just replying to the original post asking for alternatives.
  7. ess
    ess New Member
    Jun 8, 2007
    133
    Oh no not at all. I didn't see it that way at all. I wish I had a Patton here. I was just saying it can work as a solution. It may not be a "good" solution as the topic implies, but it is one that gets the job done.
