SPA-3102 how to routing PSTN calls to 3cx extensions?
Discussion in '3CX Phone System - General' started by serverx, May 15, 2011.
  1. serverx
    May 15, 2011
    I bought a new linksys spa-3102 and i followed the instruction at http: //www.3cx.com/voip-gateways/linksys-3102/ - NO LONGER AVAILABLE (first step) to configure the spa-3102 as gateway to route all the pstn calls to 3cx extensions or IVR.
    Actually i can see from 3cx "Ports/Trunks Status" that the gateway is connected to 3cx system but the calls aren't routed to 3cx extensions.
    When a PSTN inbound call rings only the analog phone which is connected to line 1 of gateway spa-3102 rings, but not calls aren't routed to 3cx extension.
    I setup the In 3CX, i have routed the pstn port (10007) inbound calls to the extensions "Connect to the Digital Receprionist" but it doesn't work, i tried to route to normal extension too but same result.
    I'll be appreciate that if I can get some help about this problem.
    10,360
    226
    There is an option in the PSTN tab...PSTN ring thru line 1, that should be set to no. Change that and see how it goes.
  3. serverx
    May 15, 2011
    thank u so much for reply...... i set "PSTN Ring Thru Line 1: no"
    but same result..... the call not forwarded to 3cx extensions...
    what it can be ?
  4. leejor
    10,360
    226
    Does the call show up in the 3CX server logs? If it doesn't then it is a setting in the 3102 (double check your settings, especially dialplan 8 ), if it does, then it is a setting in 3CX, in which case the log may give you some hints as to why it is not reaching the intended destination(s).
  5. hainesk967
    May 23, 2011
    38
    I'm having the same issue. Any update on if/how you got this fixed?
  6. hainesk967
    May 23, 2011
    38
    I figured it out. Turns out I needed to plug the network cable into the Internet port instead of the ethernet port, and set the WAN IP to address I want on my network instead of the lan ip.
  7. leejor
    10,360
    226
    They didn't do the best job in labelling that device, even "WAN" and "LAN" would have been better. The black letters on a dark background doesn't help either.
