SPA-3102 problems...
Discussion in '3CX Phone System - General' started by subh, Dec 14, 2007.
  1. subh
    Dec 4, 2007
    28
    Hi...
    Bought SPA-3102 yesterday, but having following problems:
    1. After getting connected to Digital Receptionist, after a few secs, it gets disconnected. Log as below:
    06:46:51.765
    StratInOut::eek:nHangUp
    [CM104007] Call(8): Call from Ln:10000@SPA-3102 to 100 has been terminated by Ln:10000@SPA-3102; cause: unknown
    06:46:21.515
    CallLegImpl::eek:nConnected
    [CM103001] Call(8): Created audio channel for Ln:10000@SPA-3102 (192.168.1.2:16406) with Media Server (192.168.2.2:7014)
    06:46:18.500
    CallConf::eek:nIncoming
    [CM103002] Call(8): Incoming call from 10000 (Ln:10000@SPA-3102) to sip:10000@192.168.2.2
    06:20:53.765
    [CM104007] Call(7): Call from Ln:10000@SPA-3102 to 100 has been terminated by Ln:10000@SPA-3102; cause: unknown
    06:20:21.703
    [CM103001] Call(7): Created audio channel for Ln:10000@SPA-3102 (192.168.1.2:16400) with Media Server (192.168.2.2:7012)
    06:20:21.656
    [CM103002] Call(7): Incoming call from 10000 (Ln:10000@SPA-3102) to sip:10000@192.168.2.2
    Digital Receptionist call flow:
    DR 100 --> Play Msg, wait for 2 secs, forward to DR 101.
    DR 101 --> Play Msg, wait for 1 sec, forward to extn 102.
    Ex 102 --> Forward to Voice Mail
    I have tested this with X-Lite and 3cx Phone, and it's working fine.
    At SPA-3102 Info Page, it shows :
    Last PSTN Disconnect Reason: VoIP Gateway Call Timeout
    2. After disconnecting the call, 3102 does not hang up the line. It releases the line after say 5 mins or so.
    SPA setting:
    PSTN Disconnect Detection
    Detect CPC: Yes
    Detect PSTN Long Silence: No
    PSTN Long Silence Duration: 30
    PSTN Silence Threshold: medium
    Detect Disconnect Tone: Yes
    Disconnect Tone: 400@-30,100@-30;10(.8/.8/1+2)
    Detect Polarity Reversal: Yes
    Detect VoIP Long Silence: No
    VoIP Long Silence Duration: 30
    Min CPC Duration: 0.2
    Any help would be highly appreciated.
    BTW, I'm from India and use MTNL line.
    TIN
  2. jantoney
    Nov 20, 2007
    60
    Disconect tone
    hey try change the disconnect tone to
    400@-30,400@-30;10(.8/.8/1+2)
    this is something i found on the net for india!
    i had similar issues in australia where mine wasn't releasing the call.
    i found the correct tone for australia and it worked fine after that.
  3. subh
    Dec 4, 2007
    28
    Thanks, Jay.
    I have found the correct disconnect tone for India (MTNL) :
    400@-10,400@-10;10(.75/.75/1+2)
    There are few other settings that I found which are working for MTNL, India for SPA-3102. In Regional Tab:
    Dial tone : 400@-10,375@-10;10(*/0/1+2)
    Busy tone : 400@-19,400@-10;10(.75/.75/1+2)
    Reorder Tone : 400@-10,400@-10;10(.75/.75/1+2)
    Ringback tone : 400@-10,375@-10;*(.5/.25/1+2,0/2/0,.5/.25/1+2)
    So, phone is getting released after the other side phone is disconnected.
    However, still the connection gets lost in between just around 32 seconds every time.
    Any solution would be highly appreciated.
    TIN
  4. jantoney
    Nov 20, 2007
    60
    logs
    Hey glad thats working now!
    Can you please post the logs for a call now thoes other settings have changed..
  5. subh
    Dec 4, 2007
    28
    Hello Jay,
    It's the same as before...
    3:12:27.984
    [CM104007] Call(20): Call from Ln:10000@SPA-3102 to 100 has been terminated by Ln:10000@SPA-3102; cause: unknown
    13:12:22.218
    MediaServerReporting::DTMFhandler
    [MS211000] Call(20) Ln:10000@SPA-3102: DTMF (in-band) from 192.168.1.2:16388 detected.
    13:12:21.624
    13:12:21.171
    13:12:20.656
    13:12:16.671
    13:12:16.046
    13:12:14.484
    13:12:10.765
    13:12:09.781
    13:12:08.796
    13:11:55.874
    [CM103001] Call(20): Created audio channel for Ln:10000@SPA-3102 (192.168.1.2:16388) with Media Server (192.168.2.2:7038)
    13:11:55.827
    [CM103002] Call(20): Incoming call from 10000 (Ln:10000@SPA-3102) to sip:10000@192.168.2.2
    See that it's exactly 32 seconds (excluding decimals). But this time, SPA Info shows that :
    Last PSTN Disconnect Reason: PSTN Disconnect Tone
    Hope this helps....
  6. subh
    Dec 4, 2007
    28
    SPA-3102 Experts!
    Hi...
    The problem still exists, disconnecting with "unknown" cause after 32 secs.
    Also, I'm not able to get caller id. I'm from India.
    TIN
  7. subh
    Dec 4, 2007
    28
    Well...
    I read similar problem somewhere in this forum and just followed it. It was simple.
    Backup data --> Uninstall --> Reinstall --> Restore Data.
    And the calls are now ON for minutes after minutes. ;)
    Hope this helps...
