SPA 3102
Discussion in '3CX Phone System - General' started by dyntech, Oct 24, 2007.
  1. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    In tweaking the settings on my SPA 3102, I must have changed something that effected the Caller ID. I have checked every setting and they all seem to be correct.
    Instead of the caller ID from the PSTN line I am getting the extension number setup in 3CX for my PSTN line.
    Anyone have any idea's about this?
  2. tab
    tab
    Aug 10, 2007
    85
    In the lines -> other options section you can set what in the sip header means the caller ID.
    tab
  3. tab
    tab
    Aug 10, 2007
    85
    I've forgotten to write of course in the 3cx console.
    tab
  4. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    I've tried all of these settings and nothing works. It has tobe in the SPA 3102
  5. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    I can see the correct caller ID displayed in the SPA 3102 in the "last PSTN caller" field. For some reason it does not get sent properly to the 3CX box. It shows up as 10000 which is the internal extension for the SPA 3102. :evil:
  6. Freestyle
    Oct 18, 2007
    10
    If got the same problem. Does any know how to fix this ?
  7. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Have you changed the time that the line "should" ring before passing to PBX? or the PSTN CID to VoIp CID?
    Cheers
  8. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    Freestyle,
    On the PSTN tab, FXO Timer Values (sec)- I set the PSTN Answer Delay: to 3 and the PSTN Ring Thru Delay: to 2
    I now get the correct Caller ID
