spa 3102
Discussion in '3CX Phone System - General' started by techworx, Jul 31, 2008.
  1. techworx
    Jul 22, 2008
    17
    with reference to the post by invisage,(SPA-3102 Gateway PSTN Outbound Dialling Problem) can anyone please clarify how to set up a standard ata extension in 3cx, can only see how to set normal extensions
  2. Anonymous
    Anonymous Guest
    The ATA is setup just like a normal extension, then simply connect the phone to the ATA.
    Thanks,
  3. Henk
    Henk Member
    Nov 13, 2007
    250
    Keith,
    Can you elaborate on that, my understanding was that an ATA cannot be an extension, but I am hoping i am incorrect.
    H.
  4. Stuck101
    Jul 15, 2008
    30
    I actually have an SPA-2102 setup as an extension to connect a DECT 6 cordless analog phone to 3CX, has worked out fine.
  5. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    Just add new pstn
    name it and mark spa 3102
    change the port to 5061
    then put the data in spa pstn
  6. ess
    ess New Member
    Jun 8, 2007
    133
    http: //www.3cx.com/voip-gateways/linksys-3102/ - NO LONGER AVAILABLE
    Point 19 starts discussing how to add a phone to the FXP port to function as an ATA adaptor. Basically, you can plug in any standard POTS phone to that and it'll function like a SIP phone. There are codes in the ATA setup for * codes such as transfer, etc. that you can set.
    good luck!
  7. Henk
    Henk Member
    Nov 13, 2007
    250
    Well Well what do you know,
    I might brush up the old dect phones.
    The PSTN line still functions as a PSTN incoming and outgoing?
    H.
  8. Stuck101
    Jul 15, 2008
    30
    Hello Henk,
    Yes, actually we use this daily as an active extension, no problems, audio quality has been quite good.
