SPA112 Faxing Config
Discussion in '3CX Phone System - General' started by KatWood, Mar 8, 2018.
  1. KatWood
    Oct 19, 2017
    6
    I'll keep this short and to the point.
    It's been hit or miss with faxing using Cisco SPA112s and Grandstream HT802s.
    I've configured both as "regular" extensions and fax extensions.......
    I know the Cisco 112 is not supported, but someone has to have a configuration that is "working." I hate faxing, but one of my clients is dependent on it so here I am.
    I've had great success using another PBX (almost 100% both ways) with the same SIP provider, but have hit a brick wall here. Any information provided would be greatly appreciated.
    10,778
    286
    Any settings that require enabling in the SPA will be self explanatory at they have the word "FAX" in them. Of course it's not just the ATA, that has to work, you do require using a fax extension in 3CX. I just picked up a 112the other day, and can check over the options tonight, unless someone else comes forward in the meantime. Have never used the 112 for faxing but have had some success with other (older) Linksys/Cisco models. Success can also depend on the actual fax machine being used. Some have options to set when used over VoIP, and some will always be hit or miss.
    Have a read through this, it may be of some help...
    https://supportforums.cisco.com/t5/...12-fax-settings-with-1-line-or-2/td-p/1978582
    #2 leejor, Mar 8, 2018
  3. CentrexJ
    CentrexJ Member
    May 5, 2009
    433
    67
    Once configuring the SPA112 through it's fast setup, you have to enable T.38 which is disabled by default. It works great through 3CX with SIP trunks that properly support T.38. If you are having trouble I suggest trying a different SIP provider. Babytel.net is great for Canada/US T.38 trunks.
  4. KatWood
    Oct 19, 2017
    6
    Thanks for the comments......I have had success using the Cisco SPA112 and GS with other platforms, just not 3CX. In our situation, we are utilizing the 2 port devices to push dial tone to fax machines. Our current SIP trunks support T.38. I guess I am just looking for a configuration that someone is using that is working with some consistency on 3CX. Unfortunately, I've not been able to find this information. The current settings I am using on these devices on other platforms work and there seem to be no registration issues. When placing a device on 3CX (either as an extension or fax extension) I have difficulty getting the devices to register. I guess I would just like to view someone's programming to see where I am going wrong.
  5. giwm
    giwm New Member
    Sep 27, 2016
    236
    42
    I spent too much time myself getting a SPA112 working for faxing. Too inconsistent. I ended up using a standalone faxing service. It's admittedly about $18/month but I pared down our faxes from 22 to 3 in the process once administration saw what they were spending just for fax lines.
  6. leejor
    10,778
    286
    That sounds like a different problem altogether. How is the device used? Local to the server? I've never had any registration issues with Sipura/Linksys/Cisco ATA devices. Once the settings are in and correct, they tend to be rock solid. The power supplies are a different matter.
    Here is an article on some recommended settings using the 112/122 with a different PBX, but, will still apply to 3CX. Still, these settings deal with using the 112 and a fax machine and assumes that registration problems are not an issue.
    http://www.asteriskpbxsystems.com/cisco-spa122-fax.html
  7. Flash99
    Aug 3, 2017
    83
    7
    Try these setting. Works fine for us
    Line 2
      • Line Enable - No
    Line 1
    Proxy and Registration
        • Proxy - XXX.XXX.XXX.XXX
    Subscriber Information
        • Display Name - 8XXX
        • User ID - 8XXX
        • Use Auth ID - Yes
        • Password - XXXXX
        • Auth ID - XXXXX
    Supplementary Service Subscription
        • Call Waiting Serv - NO
        • Three Way Call Serv - NO
    Audio Configuration
        • Echo Canc Enable - NO
        • FAX Enable T38 - Yes
  8. simply7
    Jan 4, 2016
    38
    18
    I hate to say it, but get 1 analog BRI from the LEC, fax and SIP is just unreliable. If you are a provider this will reduce the amount of support calls you are going to get for failed fax. Most places already have 1 line still for fire/alarm, and you can use that for outgoing fax, then route the inbound fax via your sip trunk through 3CX and deliver the fax that way.
