SPA3000 Acting up after upgrade
Discussion in '3CX Phone System - General' started by mbeijen, May 16, 2007.
  1. mbeijen
    May 16, 2007
    5
    For some reason after I upgraded to the lastest version of 3CX, my SPA3000 is acting up a bit. It seems to work fine (Accepting incoming PSTN calls, and I can use it as an extention for my fax).
    However in the server status, it shows these messages (every 15 seconds) :
    Endpoint::findSource | Can not find source by following specs: Contact IP: ''; From: '10003'; To: ''; Rline: ''; Contact: ''
    Anybody out there who can shine some light on this?
    Thanks!
    Marco
