SPA3102...Again
Discussion in '3CX Phone System - General' started by dyntech, Oct 5, 2007.
  1. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    Does anyone know how to reset the SPA3102 back to factory defaults?
    I found some settings on another forum to fix the echo problem. When I tried them, it worked great for about 4 calls and then reverted back to the echo even though the settings never changed. :evil:
    I would like to do a reset and start from scratch.
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Well to do that just...
    Disconnect Ethernet Cable and PSTN Line cable from SPA, leave only Phone and Power
    Dial ****
    you will enter then the Voice menu
    after this dial 73738 and then follow voice instruction, if i recall its 1 to confirm, you will have then your SPA with factory defaults.
    CHeers
