spa3102 and traditional phone
Discussion in '3CX Phone System - General' started by akourou, Nov 4, 2008.
  1. akourou
    Oct 20, 2008
    10
    hello,
    I have setup a configuration with a spa3102 as a pstn gateway, some spa942 as terminals and it all works fine.
    I have also setup the analog port of the spa3102 to be able to use a traditional phone as a terminal.
    From this traditional phone I can dial to the pstn and to the other terminals but it takes about 10 seconds from the time I finish dialing the number, to make the call.
    Note that when I call this traditional phone from the other spa942 terminals, it rings imediately.
    Is there a way to reduce this 10second delay?
    thank you
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello and welcome,
    Modify your dial plan to make it dial directly after last digit
  3. akourou
    Oct 20, 2008
    10
    you mean I have to go to the web interface of the spa3102 and modify a dial plan somewhere there?
    if yes, on which page exactly?
    thanx
  4. akourou
    Oct 20, 2008
    10
    I modified the dial plan on the Line1 tab of the spa3102.
    it was (*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)
    and I changed it to (xx.)
    now the time is reduced to 3 seconds
    is there a better way or it is ok?
    thanx
  5. galal202
    galal202 New Member
    Jun 23, 2008
    235
    no you have to change all the dial plan
    it depend on your extensions numbers, outbound rules ..... etc
