SPA3102 Gateway PSTN to Extension? Newbie question...
Discussion in '3CX Phone System - General' started by w1ve, Aug 3, 2007.
  1. w1ve
    Jul 20, 2007
    5
    I have been having good luck setting up 3cx with my SIP providers and extensions... Now I want to do something completely different.
    The configuration is:
    --->Cell Phone -->Dock-N-Talk--->3102 FXO Port--->3CX Extension
    3102 FXS Port<---3CX Extension
    What I want to do:
    - Be able to dial the cell phone # from another cell phone, get a secondary dial tone (PBX extension off hook) and A>either dial a prefix to get an outbond line and dial; or dial an extension within the PBX.
    So, I have the FXS port of the 3102 registered to an extension, as well as the FXS port.
    My questions are:
    - What should my dialplan be for Line 1 (should it be like any other FXS?)
    - What is the dialplan for the PSTN line?
    Right now, I've tried (<9,.:><:mad:gw1>)
    My internal IP for 3cx is 192.168.1.50; when I try this DP, I get call rejected: sip:1@192.168.1.50 is not a valid destination.
    I'm really excited to get this working... Anyone out there help?
    Regards,
    Gerry
  2. Anonymous
    Anonymous Guest
    You can do this on the SPA but not via the PBX. The PBX will be able to route the call to any number attached to the extension, but will not present another dial tone.
    Two functions in one requirement here:
    1. Dial into the SPA get a different dial tone and enter the number to dial out using the (cheap rate).
    2. Dial the SPA this gets picked up by the PBX and you can than punch in an extension that routes you to a pre-configured number.
