SPA3102 Provisioning Issue
Discussion in '3CX Phone System - General' started by adam_easyit, Sep 29, 2011.
  1. adam_easyit
    Sep 29, 2011
    We are having problems importing configs from 3CX to SPA3102.
    We have followed all instructions that we can find or source and still no good.
    We have put the URL in the Profile Rule under Provisioning, and still no luck.
    Can someone please advise or direct us to the right direction?
    Also, whats the best way to tell if the config has pulled the information to SPA3102?
    Hope to hear from you all.
    Thanks,
    Adam
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    have you used the below Provisioning URL?
    http://192.168.1.253:5000/management/provisioning/linksys3102.xml
    replace 192.168.1.253 with your 3CX IP
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    What are going to do, I mean how you intend to use your SPA3102, what type are the line(s) / extension(s) you want to connect, etc. The PSTN template provided in 3CX is useful for connecting public analog (PSTN) line to the 3CX server.
    Regards
  4. adam_easyit
    Sep 29, 2011
    Thanks, we have tried the link and still doesnt work. Not sure if the XML file contains the correct configure, how do we update this configure file if its incorrect?
    We are trying to use SPA3102 as a failover (PSTN failover) but it doesnt appear to be working.
    Can someone advise?
