SPA3102 Transfer call problem
Discussion in '3CX Phone System - General' started by pim1, May 24, 2010.
  1. pim1
    Aug 15, 2008
    15
    Hi everyone,
    I have Line 1 on SPA3102 configured as extension number. I do not use PSTN line (it's disabled), i just want to transfer call between analoge telephone connected to SPA3102 and other extensions. There are no problems with calling and answering calls.
    I have R button on telephone but it doesnt seems to work. I tried to change Hook Flash Tx Method: to AVT and INFO but without success. Any sugesions?
    Ok, everything is working fine. I've change Hook Flash Timer Min: to .01
    11,079
    324
    The default is 0.1, but that is for North America. When used elsewhere and with a pre-programmed flash, sorry, recall button, that value, and many others on the 3102, may need "tweaking"
