SPA3102 Voice delay on picked up calls
Discussion in '3CX Phone System - General' started by adams, Nov 27, 2007.
  1. adams
    Nov 12, 2007
    5
    I've configured the 3cx system with two spa3102 voice gateway. I was able to place and receive call with no problems, but if use the pickup call function (i've configured "500" for this) I got a big audio delay on the incoming calls. The audio quality is good but the delay is very high (7-10 seconds). I've also enabled the syslog server on the spa3102, and when I use the pickup call function I got an error message "TP Parser Error: 34". I've tried to bind and unbind the gateway and the extensions from media server with no change.
    Thank you very much
  2. adams
    Nov 12, 2007
    5
    Common problem
    As I can see this problem is common... There is no solution for that?
    Thank you
  3. alicic
    alicic New Member
    Oct 3, 2007
    119
    There must be a solution for that. It can not simply behave in this way, since it is not reliable, and when you answer a call the other side does not hear you, and might hang up a call.
    Please contact the producer of the Gateway, I think it is their issue.
    regards
  4. adams
    Nov 12, 2007
    5
    Linksys support reply
    I've contacted the linksys technical support, and they tell me that the problem is in the pbx... so please help me...
    Best regards
  5. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Try our latest V5 beta. We've drastically improved MS in latest versions. If it still doesn't help - then there're only two sources of probelm have left: network quality and hardware.
  6. BJReplay
    BJReplay New Member
    Oct 31, 2007
    133
    I'm pretty sure this is thrown when you have an error in your dial plan.
    As a test, revert to a simple dial plan for example:
    Code:
    (xx.)
    If the TP Parser error goes away, then you know you need to carefully check your dial plan for errors.
    However, I don't think that is the main issue, unfortunately.
  7. adams
    Nov 12, 2007
    5
    Dial plan
    I've checked the dial plan and there are no errors. The calls where received perfectly if I don't use the call pickup function. The TP Parser Error will be thrown only when I use the call pickup function.
    Thank you
