- Joined
- Oct 27, 2013
- Messages
- 1
- Reaction score
- 0
Several issues:
I'm trying something really simple! network of PC's, one PSTN line connected thru a 3102. I'd like to make and receive calls to/from the PSTN.
I set up the 3102 as VoIP gateway according to 3CX instructions. But my 3102 is s/w version 3.3.6(GW) so doesn't quite match.
Found it would register only when the User ID was set to 10000 (the extension no) - otherwise there was an authentication failure.
Now it's registered, but when I make a call it seems the 3102 doesn't know what to do with it. (log below)
Also, incoming calls don't seem to reach the 3CX - I'd expect a notification from the 3102, but nothing.
I entered my IP address in the syslog server and debug server of the 3102 and am running syslogd but get no logs generated, so can't tell what the 3102 thinks of it all.
Thanks for any clues!
regards, John.
3CX Log of o/g call:
7-Oct-2013 09:52:43.183 Call to T:Line:10000>>07703326888@[Dev:sip:[email protected]:5062] from L:3.1[Extn] failed, cause: Cause: 408 Request Timeout/INVITE from local
27-Oct-2013 09:52:43.183 L:3.2[Line:10000>>07703326888] got Failure: Failure Recv 408/INVITE from 0.0.0.0:0 tid=04134d3afd7c6b0e Call-ID=NjVkZWZlYWE3YjQxNTFiMDA2YmY5NGFlNjBhZmU1NjM.:
SIP/2.0 408 Request Timeout
Via: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bK-d8754z-04134d3afd7c6b0e-1---d8754z-;rport
To: <sip:[email protected]:5060>;tag=fc79fb7c
From: "John Marshall"<sip:[email protected]:5060>;tag=1b59771f
Call-ID: NjVkZWZlYWE3YjQxNTFiMDA2YmY5NGFlNjBhZmU1NjM.
CSeq: 1 INVITE
Content-Length: 0
27-Oct-2013 09:52:43.183 [CM503003]: Call(C:3): Call to <sip:[email protected]:5060> has failed; Cause: 408 Request Timeout/INVITE from local
27-Oct-2013 09:52:43.183 Session 1900 has failed in leg L:3.2[Line:10000>>07703326888] ; Cause: 408 Request Timeout/INVITE from local
27-Oct-2013 09:52:43.183 Failure from <sip:[email protected]:5060>;tag=fc79fb7c to "John Marshall"<sip:[email protected]:5060>;tag=1b59771f
27-Oct-2013 09:52:36.285 Currently active calls - 1: [3]
27-Oct-2013 09:52:11.062 [CM503025]: Call(C:3): Calling T:Line:10000>>07703326888@[Dev:sip:[email protected]:5062] for L:3.1[Extn]
27-Oct-2013 09:52:11.062 Route to L:3.2[Line:10000>>07703326888] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=703a2e063f00b417 Call-ID=NjVkZWZlYWE3YjQxNTFiMDA2YmY5NGFlNjBhZmU1NjM.:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-703a2e063f00b417-1---d8754z-;rport
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Content-Type: application/sdp
Supported: replaces
Content-Length: 358
v=0
o=3cxPS 290782707712 32279363585 IN IP4 192.168.1.203
s=3cxPS Audio call
c=IN IP4 192.168.1.203
t=0 0
m=audio 7008 RTP/AVP 0 8 3 13 9 110 99 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:13 CN/8000
a=rtpmap:9 G722/8000
a=rtpmap:110 iLBC/8000
a=rtpmap:99 SPEEX/8000
a=rtpmap:101 telephone-event/8000
a=sendrecv
27-Oct-2013 09:52:11.038 Outbound URI is used: sip:[email protected]:5062
27-Oct-2013 09:52:11.038 SLA is globally disabled
27-Oct-2013 09:52:11.037 Added leg L:3.2[Line:10000>>07703326888]
regards, John.
CSeq: 1 INVITE
Content-Length: 0
Max-Forwards: 70
CSeq: 1 INVITE
Supported: replaces
Content-Length: 358
v=0
s=3cxPS Audio call
t=0 0
a=rtpmap:3 GSM/8000
a=rtpmap:13 CN/8000
a=sendrecv
