spa504g works but no vociemail???
Discussion in 'Windows' started by aftermarket, May 25, 2010.
  1. aftermarket
    May 13, 2009
    84
    hi people,
    got our spa504g setup answers calls and places calls fine however when dailling the voicemail number it doesnt work (connects and theres just silence). i did have it working once but now isnt, any ideas?
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    If you dial 999 does it work?
  3. aftermarket
    May 13, 2009
    84
    its changed on our system to 121 but no it doesnt just connects and stays silent
  4. leejor
    10,360
    226
    What does the 3CX log look like after you've dialled 121, is getting though to 3CX or being blocked by the dialplan in the set? Is this just one set that affected?
  5. aftermarket
    May 13, 2009
    84
    hi, its says:
    22:03:23.679 Active calls counted toward license limit: []
    22:03:14.476 [MS105000] C:39.1: No RTP packets were received:remoteAddr=88.104.xxx.xxx:16468,extAddr=80.176.xxx.xxx:9048,localAddr=80.176.xxx.xxx:9048
    22:03:12.944 [CM503008]: Call(39): Call is terminated
    22:03:12.944 [CM503021]: Call(39): ACK is not received
    22:02:51.679 Active calls counted toward license limit: [39]
    22:02:40.929 [CM503007]: Call(39): Device joined: sip:121@127.0.0.1:40600;rinstance=06c0a03ae7b769a6
    22:02:40.913 [CM503007]: Call(39): Device joined: sip:100@88.104.xxx.xxx:5060
    22:02:40.913 [CM505001]: Ext.121: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:121@127.0.0.1:5060]
    22:02:40.913 [CM503002]: Call(39): Alerting sip:121@127.0.0.1:40600;rinstance=06c0a03ae7b769a6
    22:02:40.788 [CM503025]: Call(39): Calling Ext:Ext.121@[Dev:sip:121@127.0.0.1:40600;rinstance=06c0a03ae7b769a6]
    22:02:40.726 [CM503004]: Call(39): Route 1: Ext:Ext.121@[Dev:sip:121@127.0.0.1:40600;rinstance=06c0a03ae7b769a6]
    22:02:40.726 [CM503010]: Making route(s) to "Voice Mail"<sip:121@80.176.xxx.xxx>
    22:02:40.726 [CM505001]: Ext.100: Device info: Device Identified: [Man: Cisco;Mod: SPA Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco/SPA504G-7.4.4] PBX contact: [sip:100@80.176.xxx.xxx:5060]
    22:02:40.726 [CM503001]: Call(39): Incoming call from Ext.100 to "Voice Mail"<sip:121@80.176.xxx.xxx>
  6. leejor
    10,360
    226
    Gee,looks like the same issue as...http://www.3cx.com/forums/outbound-call-drops-after-about-30-seconds-15267.html
    Same IP and model phone too...Hmmmm
  7. aftermarket
    May 13, 2009
    84
    yea, i didnt think it was related but i've relised it is. both router have the firewall disabled and the pbx server has its windows firewall off too. really dont understand why it wont work
  8. leejor
    10,360
    226
    Time to get out Wireshark and see (confirm) where the SIP messages are being blocked.
  9. aftermarket
    May 13, 2009
    84
    really didnt want to do that!!! installed it and have no idea what to do with it
  10. aftermarket
    May 13, 2009
    84
    run that wire shark and it says that my internal pbx 192.168.1.120 is reachable yet the windows fire wall and routers fire is completly off
