SPA50x FW 7.5.2a-7.5.3 FYI
Discussion in '3CX Phone System - General' started by EuclidTech, Sep 18, 2012.
  1. EuclidTech
    Apr 28, 2011
    6
    I ran a few firmware updates on our Cisco Phones which are mostly SPA504G. After a few weeks of running 7.5.2a/b without problems on two test phones I deployed the update to the rest of the phones. The FW is mostly functional and stable but it brought to light one issue worth mentioning. Any Agent Login/Logout or custom speed dial BLF lights set on the units or side cars remain orange indefinitely. The buttons do appear to function normally. I factory reset the phones and the issue was not corrected. I then saw a 7.5.3 update so I tried it on one phone and had the same results. After downgrading back to the supported 7.5.1a everything seems to be working perfectly. I know those two FW releases are new and unsupported, I just wanted to make sure 3CX was aware of the problem for the future.
  2. netswork
    netswork Active Member
    Mar 11, 2011
    577
    Thanks for the heads up
  3. infonetics
    Sep 13, 2011
    41
    I just did the same upgrades here, all the normal BLF's for extensions are working, but speed dials and status changes are blinking orange. They function normally though.
    Back to 7.5.1a, I guess.
  4. StefanW
    Jun 2, 2009
    1,222
    93
    it will be fixed in SP2 to match the latest FW of cisco.
    You can have a go with this pre template of mine
  5. StefanW
    Jun 2, 2009
    1,222
    93
    any feat back to the template?
