SPA525G2's keep disconnecting/reconnecting since SP4
Discussion in '3CX Phone System - General' started by coldtech, Nov 13, 2010.
  1. coldtech
    Oct 5, 2010
    31
    Not sure what changed but since applying SP4 all 3 of my SPA525G2's are constantly "Refreshing Voice Component"
    I removed the auto provisioning (http://PBXIPADDRESS:5481/provisioning/$MA.xml)
    and they work as they did prior to SP4.
  2. lan3
    Sep 21, 2010
    I'm also having this same issue.
  3. tim2
    Nov 17, 2010
    My SPA525G is exhibiting the exact same behavior. I have witnessed it as frequently as every 20 seconds. It started only after SP4. Also, unlike coldtech, i am running IIS.
  4. coldtech
    Oct 5, 2010
    31
    Just for fun I poked through the provisioning template and I did not see anything that looked likely to cause this.
    Fortunately I only have 3 of these phones. If I had hundreds of them I'd be a bit annoyed :p
  5. 360fg
    Jan 11, 2011
    Anyone ever come up with a fix for this?
  6. coldtech
    Oct 5, 2010
    31
    My fix was to manually provision them and set static IPs.
    But as I said I only have 3 of these units so it was not a big deal.
  7. mfm
    mfm Active Member
    Mar 4, 2010
    641
    There is a fix for this actually, not a pretty one but there is. If you have your phones at the latest firwmare that as far as they are ever going to get, so there will be no future fixes on those devices. SO first make sure you are on the latest firmware.
    So first off go and edit the template of those devices. Please note that changing the template could cause your phone to non function or worse.
    Find the following lines:
    Code:
        <!--###       Firmware Upate Settings                   ###-->
    <Upgrade_Enable group="Provisioning/Firmware_Upgrade">Yes</Upgrade_Enable>
    <Upgrade_Rule group="Provisioning/Firmware_Upgrade">http://%%pbx_ip%%:%%pbx_http_port%%/provisioning/firmware/%%firmware%%</Upgrade_Rule>
    <Upgrade_Error_Retry_Delay group="Provisioning/Firmware_Upgrade">86400</Upgrade_Error_Retry_Delay>
    Swap it all out with this:
    Code:
    <Upgrade_Enable group="Provisioning/Firmware_Upgrade">NO</Upgrade_Enable>
    Once you have made this change, You must go to the phones sections select all the linksys phones and do reprovision. Once you have reprovisioned them unplug all phone and replug them so that they take the new settings.
    Hope this helps!
  8. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    Hi Mark,
    Is there something you know that we don't ?. Are Cisco going to make these end of life soon as well like the 525G (no '2' at the end).
    Thanks.
  9. mfm
    mfm Active Member
    Mar 4, 2010
    641
    baaah sorry guys i must have been half asleep when reading, the cisco 525g's wont be end of maintanence releases till april 6 2011, and the g2's have a long way to go. So first of sorry for the mix up, ill be editing my post up there to avoid future confusion!
    Secondly your solution lies here :)
    http://www.3cx.com/blog/docs/cisco-spa-firmware-upgrade/
    You will need to revert your previous changes.
