SPA8800 vs SN4114
Discussion in '3CX Phone System - General' started by nubi, Jan 13, 2016.
  1. nubi
    Jul 10, 2015
    Hello
    i want buy a new SIP-Gateway (FXO).
    Now i have the Cisco SPA232D, but the device crashes sometimes. So the idea is to replace it.
    I found this two products:
    Cisco SPA8800 (4xFXO, 4xFXS)
    Patton SmartNode SN4114/JO/EUI (4xFXO)
    Which one has the better compability with the 3CX System?
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    383
    52
    The Patton.
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    In theory, they should be equally compatible; but at least the Patton is an officially supported device and one that has templates for provisioning. Patton support is also very good,
    The SPA8800, as noted, has the added functionality of the FXS ports, so the comparison may not be fair if that functionality is needed.
    There may also be a cost differential, but am uncertain on this point.
    If it were me, and I only needed the FXO aspect, I would go Patton.
  4. nubi
    Jul 10, 2015
    Thank You!
    I will buy the Patton.
