SPA921 Speed Dial
Discussion in '3CX Phone System - General' started by newforest, Mar 26, 2008.
  1. newforest
    Mar 25, 2008
    12
    Hi all, any ideas on how to get a Linksys SPA921 speeddial to work properly.
    instead of the phone outputing "[sip:phonenumber@192.168.10.2] it replaces the phonenumber with the speeddial number i.e. "2".
    Any thoughts
    BR
    Ian
  2. h2009
    h2009 Member
    Mar 15, 2008
    447
    Do you mean this in the server logs?
    (i've just had the same phone arrive today - do you get any get any echoing in the line?)
  3. newforest
    Mar 25, 2008
    12
    Hi, yep thats in the server logs.
    Using the phone normally it's fine no echos (so far).
  4. newforest
    Mar 25, 2008
    12
    Sorted, it's me being dim.
    When setting up a speed dial you need to tell the phone that the input is a number, alpha or an IP. To do this edit the speed dial and then press the navigation button right then you see a tab to select the type of input. Press the key repeatedly beneath the tab until you see the type of speed dial you want.
    Ian
  5. h2009
    h2009 Member
    Mar 15, 2008
    447
    hehe you beat me too it.
    that arrow to the side is a little hard to see if your contrast it low!
