spa932 blf led stays red
Discussion in '3CX Phone System - General' started by MarcelvanKuilenburg, Dec 31, 2009.
  1. MarcelvanKuilenburg
    Nov 6, 2009
    29
    pro16 3cx and the cisco 962 with 932 works almost good. The leds on the 932 are really green. When I connect an incoming line through to the extension after the extension hangs on, the led stays red. Only after restarting 3cx the led is green again. the meaning is, that the led on the 932 turns red on using the line and green again after the extension hangs up.
    anyone any idea what i can do better.
    happy ny
    greetings
    Marcel
