SPA941 Message Waiting
Discussion in '3CX Phone System - General' started by Daikoku, Oct 8, 2007.
  1. Daikoku
    Sep 22, 2007
    28
    I have a Linksys SPA941 and am trying to get MWI working. I entered the server IP address and enabled message waiting on the specific extension. However, as soon as I turn this on, the MWI indicator is on and it shows a mail envelope on that extension even though there is no voicemail at all. I also tried to add a new voicemail, listen to it, delete it, etc. .. but the MWI indicator is active all the time.
    Any idea what's wrong here?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Just be reminded that MWI only support paid version.
    If you using paid version:
    Open your web admin page the click admin login-> advanced > EXT 1>
    Call Feature Settings:
    Message Waiting: NO <-- ** Yes will cause MWI always on even no message **
    Mailbox ID: your extension
    Voice Mail Server: your 3CX box IP or hostname
    Goto Tab "Phone":
    Voice Mail Number: 999 (default VM)
  3. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Setting this setting to NO will make MWI work on this phone.
    I am assuming that you do not have the FREE VERSION.
    Regards
  4. nbernalr
    Nov 19, 2007
    HOW TO CONFIG WMI IN SPA941
    IN TAB PHONE
    JUST ONLY PUT IN FIELD VOICE MAIL NUMBER : 999
    IN CALL FEATURE SETTINGS IN TAB EXT 1
    IN THE FIELD MESSAGE WAITING: NO
    BELIEVE OR NOT THIS WORK THIS WAY
    IN THE FIELD VOICE MAIL SERVER: NUMBEREXT@IP3CXSERVER
    AND VOILA THATS ALL
