SPA941 multiple appearances
Discussion in '3CX Phone System - General' started by Paulh, Apr 16, 2008.
  1. Paulh
    Apr 16, 2008
    27
    Hi all,
    First post here. I'm trying to setup two lines on a Linksys SPA941. I have Ext 1 setup and working fine (as Ext 101). However, I can't get the second extension (102) to work on the phone. Under the Ext 2 tab on the web setup page, I have all the same settings as Ext 1, except for Display name, User ID, Password and Auth ID.
    Whenever I try to call 101, it works. If I try and call 102, I get either line is busy or not found. If I call from line 2 (102) it shows up as if I'm calling from line 1 (101). Also, all the lines on the phone's display show 101 (instead of 102 for the second line). Line status on the server shows 102 is registered...
    Any suggestions?
    Thanks,
    Paul
  2. BJReplay
    BJReplay New Member
    Oct 31, 2007
    133
    Simple: in the SPA941 web gui, on the Phone tab, set Line Key 2 to Ext 2, and on the Ext 2 tab, make sure Register is set to Yes.
  3. Paulh
    Apr 16, 2008
    27
    BJReplay,
    That was it, thanks! Needed to set Line Key 2.
    Paul
