SPA942 as remote hardphone
Discussion in '3CX Phone System - General' started by freall, May 20, 2008.
  1. freall
    Newbie question...
    I have setup a 3CX server and configured the firewall with all necessary static NAT mappings.
    The server is reachable as "external.mydomain.com" with default ports.
    I have tested several softphone apps (3CX, Xlite) and these work just fine.
    Now I am trying to connect a Linksys SPA942 over the Internet to an extension.
    The Linksys is behind a NAT router, but I have enabled NAT mapping features.
    The phone DOES register on the server, but when I try to dial to this extension, I get the error "401 Unauthorized":
    (PS: Another Linksys phone hooked up to the LAN of the 3CX server and registered on the same extension DOES ring.)
    Extract from the log:
    20:06:17.331 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 75.101.138.128:3478 over Transport <my-internal-server-ip>:5060
    19:56:49.070 Call::Terminate [CM503008]: Call(9): Call is terminated
    19:56:45.632 CallLeg::eek:nFailure [CM503003]: Call(9): Call to sip:503@external.mydomain.com has failed; Cause: 401 Unauthorized; from IP:213.219.136.27:40676
    19:56:44.898 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(9): Calling: Shared:503@[Dev:sip:503@<my-internal-linksys-phone-ip>:5060, Dev:sip:503@213.219.136.27:40676]
    19:56:44.898 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:503@<my-internal-server-ip>]
    19:56:44.898 Extension::printEndpointInfo [CM505001]: Ext.501: Device info: Device Identified: [Man: GrandStream;Mod: GXP-2000;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.6.16] Transport: [sip:<my-internal-server-ip>:5060]
    19:56:44.867 CallCtrl::eek:nIncomingCall [CM503001]: Call(9): Incoming call from Ext.501 to [sip:503@<my-internal-server-ip>]
    I don't understand why this works with softphones and not a hardphone... What am I missing?
  2. freall
    Anyone?
  3. jparisi
    Oct 1, 2007
    92
    I tried in vain to get a 962 working like that in V5. I eventually set up a VPN between the two sites and got it working fine.
    Have NOT tried with 5.1, but it still works with the VPN
  4. ess
    ess New Member
    Jun 8, 2007
    133
    #4 ess, May 24, 2008
