SPA942 - Program Extended Function for Blind Tranfer (bxfer)
Discussion in '3CX Phone System - General' started by jjspyder, Jan 9, 2009.
  1. jjspyder
    Jan 9, 2009
    6
    I have Linksys SPA942 phones with the latest firmware and I know you can disable line keys and use them as speed dials instead. I would like to know if it is possible to program the extended function to do a blind transfer to an extension instead of a speed dial. If so, what syntax what I would I use? I have it programmed now so that I can speed dial another extension. However, I would like this button to be a one button transfer. I think *98 can be used to do a blind transfer and I was wondering if this could be incorporated into a speed dial to get it to do what I want. Does anyone know if this is possible by changing the syntax? The syntax for the extended function I have now is below. Thanks.
    fnc=sd;sub=704@$PROXY;ext=704@$PROXY
    Jason
