Speakerphone button
Discussion in 'Windows' started by francks, Sep 12, 2010.
  1. francks
    Sep 12, 2010
    7
    I'm not sure why none of the softphones provide the ability to switch from headset to speaker at the touch of a button. All real phones have that functionality and it's extremely useful. Would you be able to add a button that would allow the user to toggle between 2 sound configs?
    Thanks.
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,405
    81
    You want to be able to switch between using your speakers, and your speakers? o_O
  3. francks
    Sep 12, 2010
    7
    No :p I want to be able to switch between my USB headset and my speakers! And ideally the config would be persistent. For example if I have a config for my Bluetooth headset and another one for my speakers, the config should be disabled if the headset is not present but should re-enable itself once the connection is back on. This is something that Skype does quite well.
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    There is no such functionality at this time, please post a feature request. The only way you can do it is to play with it manually from the windows settings. Im not sure if there is a free program that would allow to switch with keypresses, might be an option you can look into.
  5. francks
    Sep 12, 2010
    7
    I doubt I could find such a program unless you provide a keyboard interface for changing audio sources which I suspect you don't have (correct me if I'm wrong). How do request a new feature then?
