Speakerphone used instead of earpiece
Discussion in 'Android' started by markcs, Jun 16, 2010.
  1. markcs
    Jun 16, 2010
    9
    Hi!
    On the X10 Mini, when answering a call, the speakerphone is activated instead of the earpiece. Are there settings to change this, or is this a fault in 3XCPhone?
  2. mannuz
    Jun 16, 2010
    Same problem with Huawei U8220 (pulse). Headset is working but not earpiece.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,117
    145
    Can you confirm that the settings of the phone are correct?
    The android native phone reproduces this problem?
  4. markcs
    Jun 16, 2010
    9
    I dont have this problem with SipDroid and calling normally uses the earpiece and not speakerphone. I do get this same problem with Linphone though ...
    I use the X10 Mini in Android 1.6
  5. nb
    nb Support Team
    Jun 7, 2007
    2,117
    145
    We are going to get hold of an X10 mini and see what is happening here.
    We will update when we have results. Probably something with screen size. Another user had a problem on X10 mini becoming unresponsive sometimes.
    Thank you for the update. We are checking
  6. mchristsen
    Mar 30, 2010
    26
    How do you switch between Speaker and Earpiece during call?
  7. nb
    nb Support Team
    Jun 7, 2007
    2,117
    145
    On my nexus one, I click on Earpiece
    An interface comes up - Earpiece or speaker
    i choose what I prefer and it routes audio to the selected calls.
    however with all these different models and phones, I cannot guarantee that this will work on each and every phone at this beta stage
  8. vincenzob
    Mar 4, 2009
    Some problem on my Samsung Galaxy i5700. The App is very unstable. When I put it on background, pressing home button, it doesn't come up again. I have to kill its process with task manager...
    The app crashes too.
    Sometime the app freeze my phone.
    A lot of work to do but great app compared to other solutions for Android SIP.
    Thank you for your work!
  9. nb
    nb Support Team
    Jun 7, 2007
    2,117
    145
    HI
    I have checked this with development
    The first generation samsung android phones: galaxy (i7500), spica (i5700), behold are known for their audio issues.
    All voip clients (also some music apps) have issues with them.
    A bit sad, but not much you can do.
    Or use at your own risk.
