speakers on softphone
Discussion in '3CX Phone System - General' started by foulad, Nov 12, 2013.
  1. foulad
    Nov 11, 2013
    23
    Good day,
    we are testing softphone for all our users , we brought headsets for each user , but when someone call and the user to putting the headset he/she wont be able to hear the ring , is there is way to connect to each workstation speakers only for ringing ?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    what about the pop-up notification that the phone is ringing... is this not sufficient?
  3. infonetics
    Sep 13, 2011
    41
    I believe you can specify an audio device for ringing? I use softphone with headset as my primary phone, so I set mic and speaker as my headset, and my PC speakers for ringing.
  4. foulad
    Nov 11, 2013
    23
    how did you do it ?
  5. infonetics
    Sep 13, 2011
    41
    Settings, audio options. There are 3 fields - microphone, speaker, and ringing. I set microphone and speaker to use my jabra headset, and ringing to use default windows audio device (my laptop speakers, in my case).
  6. foulad
    Nov 11, 2013
    23
    you mean softphone setting ? im suing the below one
    http://www.3cx.com/voip/softphone/
  7. infonetics
    Sep 13, 2011
    41
    Yes, just follow the "settings" or "preferences" link (depending on your version), and it'll be right there.
