Special button to be able to remove Orphaned Trunk Extensions
Discussion in 'Ideas' started by gcme, Dec 23, 2016.
  1. gcme
    Aug 23, 2012
    Is it possible to add a way to remove by ourself problematic extensions like Patton FXO (old way to create, 1 extensions by FXO line)
    When we removed an old Patton device (that was configured using old template), 4 trunk extensions was present. If we remove that Patton device, then only the first Extension is removed and 3CX keep 3 extensions in error in the interface
    It could be useful to have something to remove them by ourself, with a confirmation of course.
