Special incoming DID rules
Discussion in '3CX Phone System - General' started by mukkacow, Jan 17, 2018.
  1. mukkacow
    Oct 26, 2017
    44
    5
    Hello!
    When somebody divert a call to our DID we can see in logs that the incoming call has been diverted, which number diverted it and o the reason.
    It's possibile to create rules to handle them ??
    --- log ---
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
    Content-Type: application/sdp
    Date: Wed, 17 Jan 2018 09:52:30 GMT
    Supported: replaces, timer
    User-Agent: Cisco Telco System
    Diversion: <sip:+4179xxxxxxx@xxx.xxx.xxx.xxx>;reason=unavailable
    Content-Length: 281
  2. mukkacow
    Oct 26, 2017
    44
    5
    CID rules works for
    Not
    Diversion: "+41xxxxxxxxx <sip:+41xxxxxxxxx@“.
    You can’t create a rule that says: IF INCOMING CALL HAS BEEN DIVERTED FROM XXXXXXX THEN....
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    If the number is being sent to YOUR DID, then is there not already a rule in place for the DID? It is obviously hitting 3CX, but you did not post the entire log nor did you indicate what the error or issue was. You only showed that part of the log which showed the call to have been the result of a diversion. The fact that the call was diverted is of no real consequence, it matters what the whole message header was so that we can see how the call got to you and what about the header structures that prevents the call from being handled in the manner you desire.
