Solved Special outbund rule for some extensions
Discussion in '3CX Phone System - General' started by cyclone76, Apr 12, 2017.
  1. cyclone76
    Mar 3, 2017
    44
    Is it possible to apply a special outbund rule only for some extensions and note for all extensions ?
    For example, can i create an outbund rule to allow extension n° 105 to dial american numbers ?
    Regards
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
  3. cyclone76
    Mar 3, 2017
    44
    I found the solution my self.
    I create a special groupe called FRANCE FIXES where i added some extensions.
    And i associated outbund rules for numbers that begin by 01 -> 09 except 06 & 07 to FRANCE FIXES' group and that works well.
    I do not need to create outbound rules to forbidden mobils calls because i do not allow numbers that begin by 06 and 07.
    So extensions into FIXES GROUPE can only dial numbers with 10 length that begin by 01, 02, 03, 04, 05, 08, 09.
    #3 cyclone76, Apr 12, 2017
  4. leejor
    11,113
    329
    And don't forget that rules are "read" top to bottom, so, more specific rules should be above the more generic.
    cyclone76 likes this.
