- Joined
- Apr 6, 2017
- Messages
- 286
- Reaction score
- 16
The operator extension cannot be disabled, you can however either change the prompt so that users do not get this prompt or create a dummy operator extension that forwards the call to an IVR with a message and End Call after 1 second. This way no phones will be ringing after hours.There's no option to disable the operator extension, or to just deliver the call to voicemail of an extension
What reason could there be for a second set of office hours?
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
