Specific opening times for inbound rules
Discussion in '3CX Phone System - General' started by 3cxsbx, Apr 14, 2016.
  1. 3cxsbx
    Nov 18, 2015
    28
    The extensions allow specific opening times for themselves. But the problem here is that altough the external number should get "we are away" internal calls should still be routed to the extension. If the specific opening time would be set on the inbound rule, this would have been solved.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    312
    Its already like this, you can set the opening hours per inbound rule and internal calls still get routed, of course they do...
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,387
    88
