Specified CallerID for Outbound Rules(Clip noScreening)
Discussion in 'Ideas' started by timmbo, Sep 15, 2017.
Specified CallerID for Outbound Rules(Clip noScreening) 5 5 1votes
5/5, 1 vote
  1. timmbo
    Aug 25, 2017
    98
    47
    some Customers which runs a outbound Call-Center wanna have the Possibility to set the outbound CallerID for each Call.
    A Call-Center makes outbound Calls for a dozen of Companys, so the best way is to work with prefixes.
    I can sett at oubound Rules a prefix and after then i choose the Provider i cut the prefix and then i can set the outbound CallerID, so i can choose with prefixes which Number has been shown/set.
    If a Customer calls back on the specified extension what was shown at the oubound Call, so the Call-Center can answer with the specified Company Name.
    I think thats a baxic feature for Call-Centers which make outbound Calls.
    Bye
    Timm
    ITW likes this.
