SpeedTouch 716 ADSL Gateway
Discussion in '3CX Phone System - General' started by cesarsassoon, Apr 3, 2008.
  1. cesarsassoon
    Apr 3, 2008
    I am using a SpeedTouch 716 ADSL Gateway to connect my computer to the Internet it has the facility to allow me to connect 2 analogue phones which I can use to make VOIP call independently of my computer.
    I have downloaded the free 3CX software and installed it. Can I now configure these 2 telephone ports on my SpeedTouch 716 ADSL Gateway as two separate extensions within the 3CX Phone System instead of connecting SIP Phones to my computer.
    I need the to know how to complete the following fields in the configuration of my SpeedTouch 716 ADSL Gateway:
    SIP URI:
    Username:
    Password:
    Registrar:
    Registrar Port:
    Proxy:
    Proxy Port:
    Expire Time:
    Also can anyone also help me configure my incoming lines as well.
    I have a TalkTalk line as well as two VOIP lines one from VOIPCheap.com and one from sipgae.co.uk.
    Can anyone please help me configure these incoming lines.
    Thanks in advance for any help.
    Cesar Sassoon
    cesar@sassoon.org.uk
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hi Cesarsassoon
    WELCOME TO 3CX
    I HOPE YOU ENJOY IT
    SIP URI:
    Username: your ext. number EX: 101
    Password: ext. 101 password
    Registrar: 3CX server ip EX: 192.168.1.100
    Registrar Port:5060
    Proxy:
    Proxy Port:
    Expire Time: 300
  3. cesarsassoon
    Apr 3, 2008
    I do not understand your reply to my question.
    Can you clearly give me exactly what I need to enter for all the following fields in the configuration of my SpeedTouch 716 ADSL Gateway:
    SIP URI:
    Username:
    Password:
    Registrar:
    Registrar Port:
    Proxy:
    Proxy Port:
    Expire Time:
    Also can you expain how to configure these extensions within the free 3CX software - namely what to enter for the ID and Password fields and also SIP ID field.
    Thanks again in advance for any help.
    Cesar Sassoon
