speex codec
Discussion in 'Android' started by markcs, Jun 19, 2010.
  1. markcs
    Jun 16, 2010
    9
    Hi!
    Speex codec is in the list of supported codecs, but if I ONLY select speex to be used, I do not see it send in the SDP:
    v=0
    o=- 3485949799 3485949799 IN IP4 192.168.1.123
    s=pjmedia
    c=IN IP4 192.168.1.123
    t=0 0
    a=X-nat:0
    m=audio 4000 RTP/AVP 101
    a=rtpmap:101 telephone-event/8000
    a=fmtp:101 0-15
    a=rtcp:4001 IN IP4 192.168.1.123
    This must be a bug I guess.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    Yes we know about this - Will be fixed in the next release/
