spelling error
Discussion in '3CX Phone System - General' started by craigreilly, Jun 18, 2015.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
    3cx - I do not have support- so can not create a ticket... in the meetings section of 3cx for Windows you use the word "RESENT" when you should be using the word "RESEND".
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Thank you, we have forwarded this to the relevant department.
