Spetralink PTB410X
Discussion in '3CX Phone System - General' started by DanG, Apr 17, 2013.
  1. DanG
    Apr 17, 2013
    One of several requirements for an upcoming bid is wireless compatibility with a Spectralink PTB410X wireless communication system. Does anyone know if the 2 systems are compatible?
    The other is Emergency Location Services. VoIP Toys has a solution but it has not been released. Does anyone know if a released solution that is compatible with 3CX?
    Dan
