Sprint 4G compatibility
Discussion in 'Android' started by jamesdean, Oct 21, 2010.
  1. jamesdean
    Oct 20, 2010
    Are there plans for 3CX work with the Sprint 4G network or is there a workaround to use 3CX on the 4G network?
