SRV
Discussion in '3CX Phone System - General' started by Philco, Feb 23, 2008.
  1. Philco
    Philco Member
    Nov 10, 2007
    364
    Hi, I notice that sinve installing 5.1 that SRV isnt implemented or doesnt appear to be when I look at the status at the VOIP provider.
    Is there a parameter to set as I cant see one or has it been overlooked.
    Phil
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    DNS SRV or what?
  3. Philco
    Philco Member
    Nov 10, 2007
    364
    Yes DNS SRV.
    The Voip proider I use shows whether the logged in user is subscribing to DNS SRV. I know version 5 was but 5.1 doesnt appear to be.
    Phil
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    Nothing has changed in this regards from v5 to v5.1
    And, subscription for DNS SRV is something completely new for me. Can you please point it out where have you found such option? Which RFC?
  5. Philco
    Philco Member
    Nov 10, 2007
    364
    Hi Archie, well I know that when I first looked at 3cx in November last year, version 3.1 didnt support DNS SRV, but when version 5 came out I notice it did. I only know his from the logs at he VOIP provider. So just to show you i've loaded up version 5 onto a second machine, see below the two logs of version 5 and version 5.1 which clearly show. Maybe 3cx is unwitingly supporting SRV in version 5.0 without you knowing.
    Loggin status from voip provider.
    Platform Address Contact URI Expires Weight Seq Useragent
    Proxy 1 (SRV) xxx.xxx.xxx.xxx:5060 sip:144663@xxx.xxx.xxx.xxx:5060;rinstance=635254230a4c700c 25/02/08 15:18:55 1.00 2 3CXPhoneSystem 5.0.3790.0
    Proxy 1 (IP) XXX.XXX.XXX.XXX:5060 sip:994054@XXX.XXX.XXX.XXX:5060;rinstance=7c4a7f54ab377676 25/02/08 15:21:44 1.00 16 3CXPhoneSystem 5.1.4128.0
    Hope that helps.
    Phil
  6. archie
    3CX Support
    Aug 18, 2006
    1,299
    No, 3CX wittingly supports it since v5, and should support in v5.1. If it doesn't - I should fix it.
  7. Philco
    Philco Member
    Nov 10, 2007
    364
    I was getting worried when you said this Archie:
    I suppose I shouldnt have said Subscription.
    Yes looks like its not working at the moment.
    Phil
