SSL Certificate Error
Discussion in '3CX Phone System - General' started by LyonAdmiral, Jun 14, 2017.
  1. LyonAdmiral
    Aug 10, 2015
    51
    Has anyone seen this error generated from their 3CX installs?
    Lets Encrypt SSL certificate was failed to renew. Error: PostInstall.LetsEncrypt.LetsEncryptRegistrationException: Unknown license key.
    at PostInstall.CertificateHelper.ProcessCertificatesDirectory(String directory, CloudServerStatus statuses, String appBin)
    at PostInstall.CertificateHelper.RenewCertificates(String appBin, String nginxConfigFolder, String configurationPath)
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @LyonAdmiral,
    I've sent you a p.m. Please check your inbox.
  3. wirenetware
    Apr 20, 2016
    In my event log i have this message:
    SSL Certificate renewal has been failed. Error: PostInstall.LetsEncrypt.LetsEncryptRegistrationException: Unknown license key. at PostInstall.CertificateHelper.ProcessCertificatesDirectory(String directory, CloudServerStatus statuses, String appBin) at PostInstall.CertificateHelper.RenewCertificates(String appBin, String nginxConfigFolder, String configurationPath)
    How I can resolve this problem? I have to check the date and hours of my server but it is right.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    563
    @wirenetware
    Does the licence key in your PBX match the licence you installed the system? Have you attempted to change the licence key of the PBX without re-installing the system?
  5. secaura
    Sep 3, 2015
    getting a NET::ERR_CERT_DATE_INVALID error on a 3cx.eu certificate. Should this renew automatically?
    Chard
  6. YiannisH_3CX
    May 10, 2016
    7,783
    563
    Hello @secaura
    If you are using a 3CX FQDN and you have valid maintenance then the certificate should auto renew. Is your maintenance valid?
