Solved SSL Certificate
Discussion in '3CX Phone System - General' started by techdummy, Dec 23, 2017.
  1. techdummy
    techdummy New Member
    Sep 22, 2017
    211
    9
    I'm trying to upgrade the 3CX system to 15.5.
    We have a FQDN of our own, but there is no SSL certificate
    How can I get an SSL certificate and a CDR as I'm stuck with the installation.
  2. accentlogic
    accentlogic New Member
    Nov 14, 2013
    181
    77
    YiannisH_3CX and techdummy like this.
  3. techdummy
    Sep 22, 2017
    211
    9
    I'm stuck with the "GoDaddy needs a CSR which you need to generate and which will cover your external domain name. To simplify this process you can download the CSR generator and simply answer 3 questions; a custom private KEY and the CSR will be issued. " part.
    I have downloaded the CSR generator from the link provided, but it only has a few dll files in it.
    Can you let me know how the CSR can be generated?
    Thank you.
  4. accentlogic
    Nov 14, 2013
    181
    77
    Be sure to use a Windows computer for this. After downloading and extracting the CSR Generator (csrgen.zip) go to the folder and run the CREATE.BAT file.
    You should get a prompt to key in your desired external FQDN, followed by a prompt to assign a password, then your company name.
    When it completes, you will open the new 3CX folder inside the folder you extracted the files to, and there you will find the CSR and Key files.
    techdummy likes this.
  5. techdummy
    Sep 22, 2017
    211
    9
    Thank you accentlogic!
    Much Appreciated.
    Merry Christmas! :)
    accentlogic likes this.
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,362
    535
    Glad to hear the issue is now resolved. Merry Christmas to you too :)
