SSL expired
Discussion in '3CX Phone System - General' started by Andy Veal, Mar 12, 2018.
Tags:
  1. Andy Veal
    Oct 5, 2017
    61
    Our SSL on one of our PBX's has expired and not been auto renewed.
    We have 2 PBX's and one renewed successfully and one didn't.
    Do I need to do this manually?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,341
    535
    Hello @Andy Veal
    Are you using a 3CX FQDN? Is the maintenance for the key still valid? Did you receive an warning email that the certificate failed to renew?
  3. Andy Veal
    Oct 5, 2017
    61
    We are using an FQDN, as far as I am aware the key is still valid.
    V15 PBX
    Please advise on next steps as I need to access the PBX to make some changes asap.
    Andy V
    #3 Andy Veal, Mar 13, 2018
  4. YiannisH_3CX
    May 10, 2016
    7,341
    535
    Please check your inbox as i have sent you a p.m. with what we will need to further troubleshoot your issue
