SSL for Internal FQDN
Discussion in 'Ideas' started by Frank86, Mar 16, 2018.
SSL for Internal FQDN 5 5 1votes
5/5, 1 vote
  1. Frank86
    Jan 18, 2018
    30
    When web client connects to company's internal FQDN, all users see a "page not secure" warning. It'd be nice to be able to set up some sort of SSL to avoid the warning.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,800
    133
    We use the external FQDN internally :) Problem solved.
  3. Frank86
    Jan 18, 2018
    30
    What do you mean by that? Are you having internal users point their web client to the external FQDN instead of the internal one?
  4. craigreilly
    Feb 1, 2012
    2,800
    133
    I haven't changed the welcome email or anything - but on the Terminal Server, I put an icon shortcut to the https://externalFQDN site.
    If you are hosting the domain yourself, then you may need to do some DNS magic internally. But we are using a 3cx.us domain with their SSL.
    #4 craigreilly, Mar 16, 2018
  5. Frank86
    Jan 18, 2018
    30
    I'm using a 3CX.US domain with their SSL as well. It's all good when users point their 3CX web client to the external FQDN.
    But whey they are inside the office and point the web client to https://internalFQDN (in order to avoid going out to the external FQDN and back in through our firewall), that's when they get the "page is not private" warning.
  6. craigreilly
    Feb 1, 2012
    2,800
    133
    I just use the External FQDN. (Sorry - I saw my mistake in the other post)
  7. Frank86
    Jan 18, 2018
    30
    Gotcha. We might have to do the same.
    Thank you
    craigreilly likes this.
  8. craigreilly
    Feb 1, 2012
    2,800
    133
    Template change:
    line 50: <li>Go to %%WEBCLIENTURLPUBLIC%%</li>
  9. Frank86
    Jan 18, 2018
    30
    Thank you
  10. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    699
    99
    configure spilt dns - https://www.3cx.com/docs/creating-fqdn-split-dns/
    Configure your internal dnsserver to map your external fqdn to the internal IP address of the server
    Then you use your 3CX.US domain external and internal without any ssl certificate warnings
    #10 Saqqara, Mar 18, 2018
    simply7 likes this.
  11. craigreilly
    Feb 1, 2012
    2,800
    133
    Yep - I just couldn't find the link the other day. Sometimes trying to help is hurting when not enough info is provided... lol.
    Thanks Saqqara for following up with this link.
