- Joined
- Jan 19, 2016
- Messages
- 151
- Reaction score
- 0
Under PTSN Gateways I add the STA3102 as a Generic at the end of the process I was given the following information page
VOIP Gateway Created
Ports 90001 to 9001 have been created for SPA3102-882-3686
I access the VOIP Gateway web portal at
HTTP://172.16.85.1
Proxy server/sip server/register: 172.16.145.1:5060 (3CX Server)
SIP User ID:90001
Authentication ID:90001
Authentication Password: xxxxxxx
I access the STA3102
There is a ROUTE tab and a VOICE tab
No settings in the Route tab seem to have any relationship to the provided information so I am assuming the entries I need to make are under the Voice Tab which has the following Tabs
The tabs under voice are Info, System, SIP, Provisioning, Regional, Line 1, PSTN, User 1 and PSTN User
Info, System and Regional - assume there is nothing to do here
SIP and Provisioning Do not seem to have any connection to the information sheet
User 1 and PSTN User do not seem to be relevant
Line 1 and PSTN Line seem to be the best candidates but where.
Any advice or direction to documentation on how and where to put the information would be appreciated.
I have attached screen shots of the TABS
Line 1 - Could there be some entries here
PTSN - looks like there should be something here, but where
HTTP://172.16.85.1
SIP User ID:90001
