stand by
Discussion in 'Android' started by Italmatic, Oct 23, 2012.
  1. Italmatic
    May 22, 2008
    9
    I have this problem; when phone (samsung mini ) is in standby after some minutes is not more registered, so doesn't work.
    If i touch th screen it becomes immediately registered.
    Can you help me? Thanks.
    Roby
    11,105
    329
    It may be, that when in standby (I assume that means when the screen goes blank if left alone for a short while?), that Wifi is set to shut down to save the battery. You don't say if you are using Wifi or 3G.
  3. Italmatic
    May 22, 2008
    9
    I made in a way that wireless is always "on"; I think is a problem of 3cx soft android; because when i touch the screen after stand by
    wireless is ok and also from the access point I can see the phone.
    Thanks.
    Roby
  4. leejor
    11,105
    329
    I'm not using the same model phone, so it could be a problem related to that particular handset, but...on some hotspots, I have seen that registration has been lost, when I wake up the handset. This does not happen every time, and is not consistent with the hotspot.
    There is a particular restaurant that I frequent, and many times, for the duration of a breakfast, my phone will remain connected, no problem. However, on occasion, it has lost registration after 10 minutes or so. The same sort of thing has happened, from time to time, at other locations. There is no consistency.
  5. Nano_Magnus
    Jan 12, 2010
    I'm using Samsung Mini too, and I had the same problem, it looks like the softphone can't send keep me alive signal when the phone is in stand by.
  6. Mike_C
    Nov 20, 2012
    I'm experiencing the same issue with my Alcatel V860 (Vodafone Smart 2). The phone, when in stand-by mode is unable to maintain the connection alive with the access point so the softphone gets disconnected.
    Mike
